pcv connection that goes into the heads
Old Jan 17, 2010 | 07:37 PM
bobbyd's Avatar
Default pcv connection that goes into the heads
i just finished installing a ls6 intake on my car and I noticed that the hose that goes into the back of hte passengers side was cracked.
will I be ok if I put a vacuum plug on the the connection that is on the heads?
i plugged both sides with little vacuum plugs till I go get a piece of hose to run on them again.
just want to make sure nothing will be damage or that something will go wrong
