LS6 Short Block Identification...HELP
Old Jan 18, 2010 | 02:07 PM
jweb47's Avatar
Default LS6 Short Block Identification...HELP
Just bought a LS6 short block and am having trouble making a definitive identification of the year. This is important due to the cam difference in the 01 and 02 LS6. The seller mentioned he bought it from someone that had some type of affiliation with GM and said something about a GM tech facility. The block casting (12559378) is the same for both years but the laser etched code on the driver side flange (opposite side that the starter mounts to) isn't there...which would have told me what I need. Instead of the laser code there's a stamped number with several digits in the middle scraped over. What I can read: 115xxx66 or 115xxxx66 (8 or 9 digits).
Below that are some stamped letters/numbers: K034 and under that 877. Another unusual mark is a row of 3 dots stamped vertically between these 2 number sets. Here are some pics. If this looks familiar to anyone or if you need more/better pics or information, let me know. Thanks
Old Jan 18, 2010 | 07:26 PM
stangbeaterz28's Avatar
well if you have just the short block pull the rear cover and look at the cam PN
01' 385hp cam- 12560950
02'- 405hp cam- 12565308
hope this helps
Old Jan 19, 2010 | 08:57 AM
jweb47's Avatar
I knew the cam would solve it but I thought I'd have to pull it. I didn't know you could see the numbers like that. Are you sure? Thanks
Old Jan 19, 2010 | 12:02 PM
01ssreda4's Avatar
There should be a born date on the rear cover of the engine. If its the original cover that came with the block. Its etched in.
Old Jan 19, 2010 | 12:13 PM
jweb47's Avatar
There is...1711401. How do I decipher it?
Old Jan 22, 2010 | 02:34 PM
jweb47's Avatar
Can anyone help me identify this from the code? Just need to know if it's a 2001 or 2002...big difference between those. OR...tell me who can? Thanks
Old Jan 22, 2010 | 03:12 PM
ae13291's Avatar
if you have a dimple on the front top of the engine right before the intake manifold right under coolent crossover lines then its a LS if you dont have a dimple then its an LS6 block
Old Jan 22, 2010 | 03:28 PM
rice4eatingnotdrivin's Avatar
its a 01 and up... so ls6 or not its still a good block...
Old Jan 31, 2010 | 12:37 AM
01ssreda4's Avatar
Im gonna bump this back up for anyone who knows how to decipher the date code on the rear cover.
Old Apr 10, 2010 | 04:14 PM
Eighty7camarokid's Avatar
Anyone ever figure this out? My car had the motor replaced in it before I bought it and I need to know what year it is too so I can order the right parts. Had the same casting numbers (12561168).
Old Apr 11, 2010 | 11:44 AM
desertLS1's Avatar
all i know is that your car now has an LS6 block.. and parts should be interchangable wheather its an LS1 block or LS6...
Old Sep 24, 2010 | 10:34 AM
01ssreda4's Avatar
With an LS6 block, how do you tell which head bolts to order? The ones with the 2x medium length bolts or the set with all long bolts?
