5.3 heads.... GURUS
...and as far as the heads making more hp than a cam swap an ls6 has 243 castings and makes 400whp. yes the cam is diff than the ls1 but would the car still not make atleast 370+ with a good set of ported heads. than once the cam would go in its a 400+whp car yes or no??..
Serisouly????? without a cam to feed those "BIGGER" heads you can expect no more than 10-15 horsepower. I would be shocked if you can show me proof of otherwise. So, i guess ya, it would be around 360-370 depending on tranny and gear NOWHERE NEAR my cam only 410 rwhp. (with 4.10 gear mind you
)Im not trying to get into a pissing match here but this is how bad information gets passed around. Coming from someone who knew nothing about cars 2 years ago, people listen to what is said on these forums, like i did, looking for advice. Dont fill there mind with non-sense.
And on another note, how do you like that Textralia 6 puck? i havent got mine in yet. Is it not a bit over kill for your set-up? How is it around town?
Give us a call, we'd be happy to help discuss the differences & options..
http://www.texas-speed.com/shop/item...id=84&catid=20
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
. you put 410 to the wheels with just a cam? what was your setup? Im only 19 too man. I go to a SEMO in missouri, having a 400 hp car a college sounds like fun and is defintly a ***** magnet but you'll get tired of it quick, it just draws WAYYY to much attention especially if you go with a LOUD *** exhaust. If you plan on taking it to school i would get a good set of mufflers lol
