Broken cam???
Old Jan 21, 2010 | 04:00 PM
huggmess's Avatar
Default Broken cam???
My car's been running like crap (check my other threads) so I finally take it to the mechanic after changing the plugs, wires, maf, coils...he gets it there and cranks it to put it on the diagnostics....runs for a few minutes and he's checking the injectors and coils and such and it just goes POW and all the sudden has a huge rattle and knock in the top end he thinks...the back 4 cylinders were already running super bad...does this ever happen...I'm sure it's all my f'n luck
Old Jan 21, 2010 | 04:03 PM
ae13291's Avatar
sounds like you just broke a rod maybe. did oil leak?
Old Jan 21, 2010 | 04:08 PM
huggmess's Avatar
nope....or at least not that I know of...he called me and told me it started all the noise
Old Jan 21, 2010 | 08:33 PM
ae13291's Avatar
im sorry, is the engine still running? i thought you meant the engine stopped? could be a broken rocker arm, the needle bearings tend to spew out of them
Old Jan 21, 2010 | 09:55 PM
SweetS10V8's Avatar
Ive seen broken cams in old flat tappet small blocks, but not in LS engines. Our cams are pretty beefy.
Old Jan 22, 2010 | 03:07 PM
huggmess's Avatar
Yeah...he got it apart today and it was an exhaust valve on #5...broken valvespring...replaced it and he said it runs like a top...off to go pick it up....yayyyyy
