lq4 build estimate
Old Jan 25, 2010 | 08:28 PM
badblazeSS's Avatar
Default lq4 build estimate
just wanting to see if there were any similar builds and what kind of power can i expect,
370ci lq4
patriot stage 2 heads 64cc
9.5:1
tsp torquer v2 234/236 .595 .598 112 lsa
ls6 intake
bbk 80mm tb
Pacesetter 1 3/4, ory
magnaflow catback
moser 9in
4.10
M6
Compression is low to a boost setup for a later date. Thanks in advance
Old Jan 27, 2010 | 03:42 AM
jason00ss's Avatar
i take it you plan on some big dishes in the pistons to get down to that compression? kinda small chambers to get 9.5:1. i suggest you go with the l92 heads, especially if you plan on boost in the future(but you'll have to use a different intake though). also, you'll want a higher number lsa if you're gonna use that cam for forced induction. not trying to nitpick but the torquer2 is 232/234
Old Jan 28, 2010 | 01:16 PM
badblazeSS's Avatar
thanks for the reply, my pistons are -22cc and it makes right at about 9.6:1. I am on a budget and i plan on getting a cam with my turbo kit. I am going to run it n/a for a while till i get my kit later on this year. I appreciate the info.
