can a o2 sensor do this?
Old Jan 26, 2010 | 06:56 PM
00NastyZ28's Avatar
Default can a o2 sensor do this?
ok os i recently tuned my car i had a local guy do it and he has done alot of tunes for alot of my friends with hp tuners we tuned it and it ran better then ever btu when i hooked my 02 sensors back up it runs great except at idle sometimes and only sometime ill be sitting at a light and it will rev up and down like 4 times then die and the oil pressuse gouse up and down like waa.....waa.....waa really slow like it has a monstorous cam in it but it doesnt i preplaced one 02 sensor and noticed the wires are our of the back of it i think tht other 02 sensor is bad if so would this cause this idle problem
Old Jan 26, 2010 | 07:31 PM
RA032926's Avatar
bad o2 sensors can make your car run like dog ****... are you throwing any codes??
Old Jan 26, 2010 | 07:34 PM
SOMbitch's Avatar
Start diagnosing it by pulling codes or pending codes....... Tech II, Snap on etc....will read pending codes.
Old Jan 26, 2010 | 07:58 PM
ae13291's Avatar
could be o2 sensor or it could be bad idle air control solinoid or from the tune. but the oil psi guage should not do that
Old Jan 29, 2010 | 12:22 PM
00NastyZ28's Avatar
the codes say 02 sensors os im goign to try tht first but when i clear the codes it runs fine until i get on it then it idles bad and throws the code which leads me to belive it is the 02 sensors anyone got any extensions lol
Old Jan 29, 2010 | 12:28 PM
00NastyZ28's Avatar
thnaks for the help
Old Jan 29, 2010 | 01:00 PM
soundengineer's Avatar
it sounds like you may have several issues going in...
if its not throwing codes... then its probably not a hardware issue...
I would guess at a half ***/crap tune
if you dont tune everything in the tune, you can get weird things happening on different days
theres a lot of variables...and it only takes one to throw the whole tune into a tailspin on any given day
Old Jan 29, 2010 | 02:43 PM
Bo's 98 TA's Avatar
Buy the vette o2's, if you buy these then you don't have to have extensions. Good luck
Old Jan 29, 2010 | 06:54 PM
00NastyZ28's Avatar
thanks guys
