is this cam good in my car
Old Jan 26, 2010 | 09:02 PM
BlackBirdRyder02's Avatar
Default is this cam good in my car
specs: cam duration- .228/.240 lift- .571/.590 lobe- 113.0
springs are LS6 style with .600 lift
its a ls3 cam ...and my mods are p&ptb ls6 intake stock gears built a4 with 2800-3000 stall with long tube,lid, headers and tune and stock heads
Old Jan 26, 2010 | 09:24 PM
hard huh
Old Jan 26, 2010 | 09:34 PM
desertLS1's Avatar
Can you even put an LS3 cam in your car?
I personally think you can do better.. Especially with the stall size...
Do it once do it right man...
Old Jan 26, 2010 | 10:20 PM
chase3's Avatar
Lol every ls motor has the same cam design and can be interchanged. the new factory cams are single bolt as opposed to 3 bolt but still most aftermarket ones are 3 bolt and on an ls3 you would just change out the cam gear.
Old Jan 26, 2010 | 10:49 PM
ae13291's Avatar
the LS3 cam i dont think will work on the car but i may be wrong. as for the specs i think you should atleast be in the .600's lift and work on the intake duration atleast a bit more
Old Jan 26, 2010 | 10:58 PM
LS1-NAVY's Avatar
with that stall i personally would go with a 228/228 or maybe even the el torro cam
