ls6 heads on 98 z28
in general not much
I got most of the parts i needed from the ws6store.
-head gaskets
-head bolts
-new header gaskets
-spark plus
from the ls1tech classifieds:
-99+ valve covers
-coil pack brackets
(keep an eye on ebay as well)
from Metco Motorsports
-valve cover breather (i deleted my PCV system and just ran an open breather setup)
you dont need an ls6 manifold. you might as well swap one in while you have it off, but its not necessary to complete the job. if you dont got long tube headers, you might want to install them now while you got the best opportunity. you can also install poly motor mounts easily with the manifolds and heads out of the way as well. get a coolant temp sensor and an OPSU now. I broke my coolant temp sensor while reinstalling the headers and had to wait a week for the part store to get one in stock as the coolant temp sensor and OPSU are specific to 98's only
