going 6.0 need help
Old Feb 9, 2010 | 10:29 AM
99w69kitt's Avatar
Default going 6.0 need help
Need help choseing a cam I have the rest of my bolt ons from my ls1 bbk intake &tb headmen lt 3800 yank stall TnT nitrous kit. Thinking about spraying 200 shot. It has the 317 heads and woundering if its worth buying the l92 heads to raise compression. All help will be appriciated its going in my 99 ta
Old Feb 9, 2010 | 11:06 AM
InsaneDomestics's Avatar
Contact Shawn @ VA Speed. He knows what he's doing and he'll spec a cam that will get you the most out of your setup.
Old Feb 15, 2010 | 06:00 PM
99w69kitt's Avatar
alright i am between 3 cams 226/232 .609/.604 114 lsa 231/235 .617/.621 110+1 or the trex cam. I am just confused to weather keep the 317 heads or get the l92 heads
Old Feb 15, 2010 | 06:19 PM
tspence45's Avatar
If you get L92 heads, you'll have to get an LS3/L67 intake. And you probably won't be able to run a cam as big as the Trex, due to PTV clearance with the big valves in the L92 heads.
Old Feb 16, 2010 | 05:45 PM
99w69kitt's Avatar
great info i am going to use my bbk intake
Old Feb 17, 2010 | 12:42 AM
99w69kitt's Avatar
anybody have a stock 6.0 with 317 heads with a cam?
