Effin A -- Nightmare first cam swap...
It took me 5 nights, and then took another 5 nights, haha. When I did it the first go round I used the stock rocker bolts. I had an appointment with PatG the next morning 120 miles away in Victoria. The exhaust rocker bolt was stripped at 1AM and I said **** IT, its either going to hold, or give me a finicky excuse to buy new heads.
Drove to Victoria, dyno/street tuned it. 5 miles outside of Victoria. TAP TAP TAP TAP. ****! Towed it home(free AAA) and found the bolt sheared. Took another 5 days and swapped to 799 heads and NEW rocker bolts(2 of which the threads were FUCKED).
All was well in the end. Congrats and enjoy! Whats the point of all this if there isn't a heartache or two along the way.
some how a lifter wiggled past the rods and fell into the oil pan... but i managed to snake it out. Then after all of that and putting on the alternator for the finishing component i drop the bolt for it and i couldnt find it... so i jacked it up and BAM!! oil was spilling out everywhere under the car... the alternator bolt was sitting on the transverse leaf spring, and when i jacked it up it bowed and forced the bolt into the oil pan.
so i had to drop the subframe and get the pan off and weld it up...
it was a major pain doing all of that, but of course i learned from that(not to do it on a Z06 again)
I look forward to swapping the cam in my new engine with it outside of the car. I'll just wait for the money instead of going through installing it and then having to tear everything down again to swap the cam.
Congrats on the install man, I'm doing a cam install on my truck right now. I've been working on it for almost a week doing 30 min. to an hour at the time and stopping when I get pissed off. Its worked out much better this way; if I'd had to do it in a weekend the truck would probably be burnt to the ground by now because I'd gotten mad and set it on fire.
So being a machinist by trade I took it on myself one weekend to make an copy of the tool out of steel and improved it so it will work on other stuff then just LS heads.
Ah, don't tell me that. I bought that thing thinking it was going to make the spring swaps easy. I guess I'll have to mod it, too, if it goes to crap on me.
I could see how this could be a problem, but it worked flawlessly for us.
I got steel rods for my lifters. Measure twice for length and cut once for the rods.
To the OP .... I hope you replaced the lifters while you were in there.
1. I was only pulling the passenger head, so I had no intention of pulling the driver's head to get to the other four lifters. I inspected them, and the four lifters seemed to be in good shape (the car is running fine now).
2. I already had my pushrods (7.425), and since the replacement ls7 lifters are a different length than my stock ls1 lifters, I figured I would need to run different length pushrods on the passenger side than the 7.425 I was going to be running on the driver's side. For obvious reasons, this wouldn't be an ideal situation.
Was my thinking off track?
hey your buddy clayton doesnt happen to have a srt4 and used to have a dodge omni and a shelby csx? if so have him email me! zachtower@yahoo.com
Didn't read or realize you were only doing one head.
