carb LQ9 cam question
Old Feb 9, 2010 | 09:59 PM
68LS1WANNABE's Avatar
Default carb LQ9 cam question
The dec 07 Hot rod does a test with a stock LQ9 with l92 heads. THey dynoed 540hp with a victor jr intake and 750 bill mitchell carb. The cam used was a Crane HR-232/367-251-10 2A. PN 144HR00135. If I redo this combo with the stock 317 heads what hp can I expect? Is there another cam combo you would run to perform better than this one? Preferably a mass produced one that I can find for a budget price in the for sale section. I realize the 317 are not as good as the l92s but that's all I can spend for now. hoping to get around 500 hp with the carb, cam, and long tube headers.
Old May 25, 2010 | 11:30 PM
Maybe some more info would help.
advertised dur: 289/293
@ .050in tappet lift: 232/236
lift @ valve: 0.624/0.624
110 LSA
Will a MS3 or MS4 make this kind of power?
Old May 26, 2010 | 01:03 AM
SOMbitch's Avatar
The L92's and 317's like totally diff cams. I would sell your 317's and look for a deal on some L92's. L92's are pretty inexpensive and would be well worth the wait until you can pick up a pair IMO.
Old May 31, 2012 | 06:59 PM
lets bump this up. never got a answer.
Old Jun 2, 2012 | 03:10 PM
speedtigger's Avatar
Old School Heavy
That is a pretty good looking grind for a carb cam. What is the intake centerline/advance on that cam?
Also, if you post in the carb section sub forum, you will find more people that know about carb combos.
Old Jun 3, 2012 | 10:29 AM
onefast84's Avatar
I am running an comp xer281hr-12 in my 1984 camaro 825 mighty demon and 1 7/8 hawks headers 6.1l with 317 heads car runs 11.50s! This cam is a little smaller, but it runs great, and ever better when you can get the compression up!
