rocker arm confusion
i've come across new rocker arms for it with ratios as high as 1.85:1. just wondering how big can i go with the ratio on a stock cam before the vavles start making contact with cylinders. chances are i will just stay with the stock cam forever.
any comments or concerns would be greatly apreaciated
thanks
-dave
The only thing you are gaining is lift and doing so in a very unsafe manner. If you want more lift get the cam that has the lift you want.
You need to get a cam that 1 works with the 1.8 rocker ration safely. 2. you need to upgrade your springs, rods, heads and everything that will work with that rocker ratio and like stated above once you have safely worked your whole valve train to work on a 1.8 rocker ratio the money spent would have been better spent on a cam that would gain you HP.
Rockers DO NOT make any DIFFERENCE in hp Gains. at best you are looking @ 1 to 2 hp gains that are with in the margin of error of any dyno and not noticeable.
Bets advice get the trunnion upgrade for the stock rockers. That way you can go beyond a .650 lift and do what ever cam makes your heart flutter. with the LS6 you can see cam sizes in the 24X/24X easily with no issues and a higher duration with no ptv issues than in an LS1.
Good luck.
