Compression Ratios
Old Feb 13, 2010 | 02:27 AM
gta3uzi's Avatar
Default Compression Ratios
Hi. I'm trying to figure up a spreadsheet to calculate compression ratios.
I'm using this engine as an example just because it looked good:
http://texas-speed.com/shop/item.asp...d=827&catid=28
bore : 4.005
stroke : 4.1
deck height : 0.0015
Piston offset in cc : -11
gasket bore : 4.1
compressed gasket thickness : 0.038
Chamber Volume : 64
I had to guess at the deck height and gasket bore / thickness. I used this article to get my figures:
http://www.carcraft.com/techarticles...tio/index.html
I come up with a 14.75:1 compression ratio. Isn't that a bit high? Am I buggering something up somewhere? What did y'all get?
Old Feb 13, 2010 | 06:44 AM
Top Fuel's Avatar
I got 11.25:1. make the 11cc's positive and deck height negative. btw, I didnt use whatever equations that were in the article. I'm lazy and use compression calculators
Old Feb 13, 2010 | 07:09 AM
69LT1Bird's Avatar
Here is a decent calculator
http://www.kb-silvolite.com/calc.php?action=comp
Old Feb 13, 2010 | 08:34 AM
gregrob's Avatar
11.17 for me
Old Feb 13, 2010 | 09:26 AM
batboy's Avatar
I got 11.125 CR using the standard GM MLS gasket thickness of .051" or if you use Cometic .040" it'll be 11.41 CR. That's assuming deck height is the usual .01" and you use the preferred gasket diameter of 4.03".
This is the CR calculator I always use:
http://www.csgnetwork.com/compcalc.html
Old Feb 14, 2010 | 02:08 PM
gta3uzi's Avatar
Thanks everybody Need to do some looking into engine-specific deck heights and gasket thicknesses next time I think.
