How is my car going to run?
mti lid with k&n filter, fast toys ram air, metco breather, msd 8.5 wires, ngk tr6's, shaner stage2 throttle body, gm ls6 intake, maf translator, asp underdrive crank pulley, LS1-Edit tuning done by Norris-Motorsports, thunder racing 224/224 561/561 114 lobe cam, TEA 5.3L stage 1.5 heads, comp hardened pushrods, comp adjustable timing chain, agostino prepped ls6 oil pump, flp long tube headers with off-road pipes, whisper aggressor cat-back exhaust, vigilante 3200 stall converter, trans-go shift kit, b&m 18k tranny cooler, prothane tranny mount, gm 3.73 rear gear with auburn pro differential and TA performance cover with girdle, eibach pro kit, bmr adjustable torque arm, bmr weld-in relocation brackets, g2 control arms, g2 adjustable panhard rod, global west weld-on subframe connectors, powerslot front rotors, hawk pads, 17x9.5 zr1/ss polished wheels, Nitto DR's, Tnt wet kit 100 shot
Dyno: 367.2 hp (NA)
467.3 hp (tnt 100 shot)
With a very similar combo (N/A) i have run deep into the 10's.
I would recommed a more aggresive converter.
But your tires are not going to allow you to do much of anything off the line.
Good luck.
