tr 224/224 112 or 114, and other question
Old Feb 22, 2010 | 09:43 PM
chevy0128's Avatar
Default tr 224/224 112 or 114, and other question
It is my daily driver so im trying to stay as reliable as possible. It is a 2002 z28 M6 with lid intake , pacesetters and ory. How long or far could i safely drive this car without a tune. Also what should i go with the 112 or 114. Pros and Cons for my setup would be appreciated.
Old Feb 22, 2010 | 09:46 PM
chevy0128's Avatar
Also what cam would be one step up from the 224/224
Old Feb 22, 2010 | 10:10 PM
99LS1Bird's Avatar
drive it like a grandmaw and you should be safe for a good long ride i had the tr 230/224 i loved it
Old Feb 22, 2010 | 10:18 PM
chevy0128's Avatar
was it your dd?
Old Feb 22, 2010 | 10:20 PM
99LS1Bird's Avatar
yep i wish i wouldnt have gotten rid of it sometimes. im about to put a 5.3 in a 97 cobra i mite go with the same cam
Old Feb 22, 2010 | 10:27 PM
WeathermanShawn's Avatar
On a M6 a 224/224 112 is a good choice. I take it you have the LS6 Intake? A cam that revs up to peak power ~ 6300 RPM's is a good choice.
You will even have a nice little lope, if that is what you want.
If you are trying to step you could go to a 226/228 112+2 or a 228/228 112+2..That might get you an additional 10-20 HP. I would not go over ~6 degrees of overlap.
It might be difficult to go without a tune. All those cams will change your VE, and will need some additional air and fueling changes to get it to idle properly.
But, it is worth it. Good luck..
Old Feb 22, 2010 | 10:32 PM
chevy0128's Avatar
I really do like the lope but from what I understand that doesnt go well with drivability.I just dont want it to be in the shop constantly. And yes it has ls6 intake , pacesetters LT and ORY and cutout, and intake
Old Feb 22, 2010 | 10:39 PM
I initially had a 220/220 114+4 cam (emissions cam). I actually liked it. It had just a little 'burble' at idle. It made good power right up to about 6200-6300 RPM's.
If idle is a concern, just go with the 224/224 114. That is probably right at the 'sweet-spot' for a daily driver who wants additional HP but still wants a decent idle.
Old Feb 22, 2010 | 10:41 PM
massls1guy's Avatar
I've put about 50k miles on my TR224 114lsa over the last ~2 years. Great daily driver cam.
Old Feb 22, 2010 | 10:46 PM
chevy0128's Avatar
but will i bee able to feel the gain noticably with the tr 224/224? and what is the difference between 112 and 114
Old Feb 22, 2010 | 10:57 PM
99Bluz28's Avatar
A step up from the 224/224 would be a 228/228. IMO, you might want to look at a 224/228 or a 226/230 since you don't have high flow heads.
A 112 lsa will give you a slightly narrower peaked power band with better low end power, and a 114 lsa will give you a wider, less peaked power band.
