Big Cam
Old Feb 23, 2010 | 01:54 AM
00pewter's Avatar
Thumbs up Big Cam
lunati cam 237 237 114 595 595..installed in my ls1 trans am 99 with stock ls1 heads will it work.???????
Old Feb 23, 2010 | 02:30 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
We can sit here all day and tell you it will "fit". Measuring is the only way. QUICK ANSWER: Don't blame me if it doesnt, but I have run alot bigger on milled heads and there was no issue. It will work, but is it the cam you want to use for whatever you are going to be doing? Most cams "work". We are going to need a history of what all the car has and what the future holds for it as well to give you a better idea.
Old Feb 23, 2010 | 02:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
BTW: thats not a big cam by todays dick measurement system we use here on tech. Thats the new 224.
Old Feb 23, 2010 | 08:51 AM
mark21742's Avatar
So true, but why is that, is it because of better tuning or is it that more people are willing to sacrafice drivablity for alittle more top end nowadays?
Old Feb 23, 2010 | 08:57 AM
miller456's Avatar
depends mainly on how good your tuner is and what your willing to work with. I had the ms4 in my car and drove nearly stock, had mild bucking below 2k every now and then but nothing to frown against. I just hate what it takes to make a big cam useful and I'm going custom grind this time.
To the OP, that cam isnt big at all really and would most likely fit just fine but as stated measure to be sure.
Old Feb 23, 2010 | 01:07 PM
00pewter's Avatar
thanks ill messure the cam on the block over the weekend thanks.....
Old Feb 24, 2010 | 05:04 PM
moeZ28's Avatar
I daily drove a 347ci heads/cam (TREX V2) with an aluminum flywheel...that was fun! Your cam will fit just fine...On the stock 1998 shortblock and heads, I ran a Comp 238/240 .605/.609 112 LSA and turned it to 6800 rpms. You will be fine.
Old Feb 25, 2010 | 05:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You probably had less clearance than you wanted. Did you not run a relief of any sort?
OP - If you can easily check the clearance its a handy piece of info to have if you ever wanted to change anything up. You would be able to know what your limits are personally and physically.
Old Mar 20, 2010 | 02:09 AM
Duffster's Avatar
Little late w/the reply, but other than lift durations, thats the SAME cam I've got with my 241s and I've got near 10K miles on it. It'll work.
Old Mar 20, 2010 | 10:21 AM
SOMbitch's Avatar
Old Mar 20, 2010 | 12:57 PM
02*C5's Avatar
am running a 23X/24X custom grind by Ed Curtis and I have no issues. Ed said it would fit, I still measured and am happy with the results.
Old Mar 22, 2010 | 03:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by SOMbitch
Haha, its true though. Should put that in my sig... hmmm.
Old Mar 22, 2010 | 10:05 AM
SOMbitch's Avatar
Yeah that is sig worthy I got a good belly laugh out of it
