Torqueing of Rocker bolts....
Old Dec 28, 2003 | 02:37 PM
Ryan04Silverado's Avatar
Question Torqueing of Rocker bolts....
I was in the process of torqueing the first set of bolts for the rockers(Yella Terra 1.7) and it appears the torque wrench took a **** as it did not click at 22 ft lbs. Possibly over tightened the bolt. Anything to worry about? Should I back it out and re torque it with the new torque wrench?
Thanks.
Ryan
Old Dec 28, 2003 | 03:09 PM
Jabroni's Avatar
There may be something to worry about if the bolt has been stretched with the overtightening. Back it out very, very gingerly and make sure there's nothing else awry and reinstall a new one if you can get one. The first one may have experienced some strain that won't be forgiving for long. Try to take it easy so you don't snap it off in the head. I think you'll be fine but just use caution.
Old Dec 28, 2003 | 04:07 PM
2002SilverWS-6's Avatar
Definately take your time and go back and retorque.
Old Dec 28, 2003 | 04:19 PM
Boosted LS1's Avatar
Can you rerverse the wrench setting to see what torque you actually used when undoing it? I agree with the above, if your worried then change it as a precaution. Also, I'd check the threads in the head are ok, sounds like they will be fine but take a look anyway.
Old Dec 28, 2003 | 04:47 PM
Thanks for the inputs guys. I backed it out and reinstalled it but it would not go to 22 ft lbs of torque. I could not be without the car so I finished the install with it and started the car and it is running fine, but I will get a new bolt and redo that rocker bolt. The one good thing is that the car will be sitting for the next 2 weeks since I will be on vacation. If I have to rethread the bolt hole, is that possible? The whole head would not be scrap if the threads in the hole are stretched would it?
Thanks again for the info.
Ryan
Old Dec 28, 2003 | 05:04 PM
OK, after running the car longer, it sounds like there is a problem. I am hearing a loud clanking from under the valve cover where I had the problem with the rocker bolt. I am going to pull it apart after it cools down and take a look.
If it is jacked, what will be my avenues of resolution? Please tell me there is an easy and inexpensive resolution to this.
Thanks a bunch.
Ryan
Old Dec 28, 2003 | 06:18 PM
Help!!!
Old Dec 28, 2003 | 07:25 PM
Help, I am positive I did not cross thread it as the screw went into its place by hand just fine, but as I stated above, the torque wrench was not working and I over torqued the screw/bolt. So, as seen in the picture I appear to have stripped out the threads in the head where I bolt down the rocker. I need some help here folks, please give me a hand. I need an easy and inexpensive solution to this problem. Thanks in advance.
Ryan
The silver stuff in the one bolt is the threads from inside the head as they are also missing per my inspection there. There are threads, but deeper inside the hole.
Old Dec 28, 2003 | 07:34 PM
distortion_69's Avatar
You will have the install a helicoil if you damaged the threads. They are like $40 at NAPA. I'd have somebody who has installed one before assist you.
Peace,
Old Dec 28, 2003 | 07:35 PM
Roger that. Thanks. Anybody else?
Ryan
Old Dec 28, 2003 | 07:39 PM
cm02WS6's Avatar
Helicoil is the only thing that comes to mind, because it looks like there are a lot of stripped threads there (too many to get a longer bolt and use the remaining good threads).
Old Dec 28, 2003 | 07:47 PM
frcefed98's Avatar
take the head off and take it to a machine shop and have them heli coil it. I also have a set of 98 heads that I will sell for 100+shipping if you need them.
J
Old Dec 28, 2003 | 07:55 PM
Is this Helicoil install really that difficult to do? I am pretty competent, the only reason this happened was because the damn torque wrench was not working, all the other rockers went on with no problem.
And I do not necessarily have to take off the head right? The damaged threads are in the #2 cylinder rocker mount, and the forward most mounting hole as well, so access is pretty easy there.
I can follow instructions pretty well, so is this something I can do?
Thanks again for the assistance.
Ryan
Old Dec 28, 2003 | 09:22 PM
Billnz28's Avatar
Helicoil requires you to drill the out the threads, then tap the hole with threads, then thread in the helicoil, so its not all the easy so you better be careful , probably should have someone do it that has done it before
Old Dec 28, 2003 | 09:57 PM
Reboot's Avatar
If I'm not mistaken; aren't Yella Terra's supposed to be torqued to 25 instead of the 22 the stock rockers require?
Old Dec 28, 2003 | 10:14 PM
Thanks again for the info people. I appreciate it. I have a friend that has done some before so we will tackle it when I get back from vacation.
Everywhere I have read, they recommend the stock 22 lb ft.
Thanks all.
Ryan
Old Dec 29, 2003 | 12:02 AM
Jabroni's Avatar
Address it soon because you'll be looking at f-ing up a lifter if the preload is that much off. Then you will have to pull the head.
Old Dec 29, 2003 | 12:12 AM
Im not sure what you mean? Can you explain? The preload I have is minimal at best with my set up. Everything fit nice and tight. From what I have read, preload is no good, could cause valve float, right?
Let me know what you meant or if I read what you wrote wrong. Thanks.
Ryan
Old Dec 29, 2003 | 12:35 AM
eallanboggs's Avatar
Your arm has 3 built-in torque wrenches. You should always use them while using the one you bought just in case it fails as yours may have done. Your wrist is calibrated in in./lbs., elbow in ft./lbs. and your shoulder is for the crank pulley bolt. If your built in torque wrench ever reaches its' limit you know your mechanical torque wrench has already failed and a little lite in your brain should have come "ON" by then. Apparently someone unscrewed your lite bulb. Go out and buy a new lite bulb, screw it in and you should be OK.
Old Dec 29, 2003 | 12:41 AM
And you never make mistakes right.
If you can not help someone out with a constructive comment, just keep your mouth shut.
