Texas Speed motor? Come on in
Old Mar 2, 2010 | 12:56 AM
1slowfbody's Avatar
Originally Posted by conan
Bought my forged 347ci from them back in 05 and have never had a problem with it.10,000 miles of boost and running strong. Changing my blower pully and adding meth in about a week, hopping to hit my goal of 600hp up here in this thin air. Not worried about my bottom end one bit.
your 317's are they stock? what PSI are you running at?
Originally Posted by tording99Z28
I think you guys have convinced me to go the Texas speed route. They seem to have better prices than anybody on motors and very few of you have indicated you had any problems and when you did it sounds like they fixed it which means they have good customer service.
not sure how true this is but i saw on another site i'm on that sunset racecraft are actually the ones who build the engines you get from texas-speed and scoggin dickey, so in other words they are a distribution centers just going off what i was told
Old Mar 2, 2010 | 01:45 AM
98RedBird's Avatar
That is true.
Old Mar 2, 2010 | 05:51 AM
tording99Z28's Avatar
Very interesting. Good to know.
Old Mar 2, 2010 | 09:11 AM
conan's Avatar
My 317's are ported/polished, stainless valves, dual springs, and titanium retainers. I see 10#'s of boost max right now, should be in the 14-15 #'s with the pully swaping.
Old Mar 2, 2010 | 09:23 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Thanks for the feedback everyone! OP: Let us know if we can help with your build!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 2, 2010 | 10:02 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by 98RedBird
That is true.
We are not distribution centers for another builder's shortblocks. We both use the same elite machine shop (one of THE top machine shops in the country) but that is the only connections. The machine shop prepares and assembles our shortblocks to our individually supplied specs with our supplied parts. We do not buy and resell another shop's shortblocks as our own, we have our own custom shortblocks assembled by one of the best machine shops in the country in order to provide the best possible product to our customers.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 2, 2010 | 10:44 AM
1slowfbody's Avatar
what compression ratio are you running and what pistons?
my apologies, i didn't mean to refer you or TSP as distribution centers
Old Mar 2, 2010 | 11:26 AM
conan's Avatar
Mahle pistons with -4cc relief. Compression is around 9.4:1
http://mycarpics.shutterfly.com/176
http://mycarpics.shutterfly.com/193
Old Mar 2, 2010 | 11:59 AM
Ram4whldr's Avatar
Texas Speed built built my forged LS7 in my Z06. Great customer service and a great product as well!
Old Mar 2, 2010 | 03:29 PM
supersick99z's Avatar
Never bought a motor from them, but what I have bought from them I have loved! Good prices and service if you go about it the right way!
Old Nov 12, 2024 | 12:56 PM
garyhe29's Avatar
Default 408 Sledgehammer
Not sure where it is going to go yet but will share my experience so far. Bought their 408 Sledghammer short block. Builder got it installed. Did break in run. Started the tune process. Started having a clatter. Shut everything down. Tore down motor. Found cam bearing failed. These are bearings installed at Texas Speed. It is a Texas Speed cam as well. The engine didn't make it to actually doing dyno pulls before failure. Less than 2hrs of run time. Called Texas Speed and was told that they will not warranty a bearing failure. I sent them email after we found it was indeed the cam bearing and waiting for reply. Hoping they will make it right but skeptical. We will see. Will keep everyone up to date.
Old Nov 12, 2024 | 09:13 PM
  #32
13qtr's Avatar
Good luck....they already got your money. I'm rebuilding a texas speed darton sleeved 427 that they screwed up on the build. Was line honed crooked, the darton sleeves was notched for the rods, with what looks like a dremel and a punch. Bore looks to have been done with a dingle ball hone.
