bad head gasket or what
Be sure your pcv is working and you have the correct pcv valve in there.
If the pcv is not working properly ie not enough air flow, that will cause more condensation .
the pvc being rigged may not allow the engine to breath.
busted head gasket will also show the oil dipstick being overfilled.
can you change the oil and notice any water-oil mix?
radiator coolant low?
man thats about all i know to check, with the symptoms you have
im limited knowledge i guess
