wiseco k1 rotating assembly
Old Mar 2, 2010 | 03:41 PM
redsilv's Avatar
Default wiseco k1 rotating assembly
anyone using those rotating assemblys from wiseco?
4.125 crank with .03 bore in a lq9?
good results?
bad results?
just curious
Old Mar 2, 2010 | 04:08 PM
redsilv's Avatar
i have been eyeballing one and was wondering if any of you guys heard or know of someone that has installed
Old Mar 2, 2010 | 05:19 PM
bww3588's Avatar
that is way to much stroke for an LQ9. people with a 4 inch stroke are having problems with piston rock. taking it another .125 is just asking for trouble.
Old Mar 2, 2010 | 05:36 PM
sixt9er's Avatar
good results?
bad results?
just curious
There was a thread about this recently. Run a search and you will get a lot of mixed results. There are guys running that particular set-up (4.125 stroke/4.030 bore). It can be done. The thread had mentioned that particular combo might be prone to "using oil". I was inquiring about that set-up, because I had found a good deal on a 4.125" stroke, 4130 steel crank. After talking to my machine shop, reviewing the thread and looking in the GMPP catalog (they stated 4.0" be MAX stroke for an LQ4/LQ9), I opted not to do it. No need to second guess The General.
Old Mar 2, 2010 | 06:39 PM
redsilv's Avatar
thanks guys.
feedback on the assembly is appreciated
i was seriously considering
