Oil Pressure Problem(Have Searched)
Or it could be bad spark plugs like the Fastvet said
WTF was that comment
I have the same thing but in the water pump. The water temperature gauge was flactuating. It drived me crazy. I check it my self the engine and found the water level in the cooling radiator dropps to 3/4 level of the cooling radiator only with no traces of leaks. Went to shop and check the radiator and the water pump and found very intersting thing that causes this mess, it was a loose anchor rod that hold the pump at the left side causing clearance only when the engine becomes real hot at WOT but duirng the cold start no water leak is there. But when real hot the water start to leak in droplets slowly but it evaporate very fast since the engine and the accessiores and you can not see any treaces of leak but you can smell the radiator cooling water vapor only. The shop showed me that and ensured to tightened in cold & hot engine condition...
