Help oil pan/pump
Old Mar 7, 2010 | 03:12 PM
banditz28's Avatar
Default Help oil pan/pump
Im in the middle of a cam swap but I can't seem to be able to lower the oil pan to switch out the pump. I've been following ls1howtos instructions but it just won't budge and I don't want to break anything. any tips would help. thanks in advance
Old Mar 7, 2010 | 09:23 PM
1NASTYZo6's Avatar
Did you remove the two rear bolts which go thru the bellhousing and into the back of the pan?
Old Mar 7, 2010 | 09:55 PM
Spoolinsteve's Avatar
Old Jun 2, 2010 | 05:47 PM
I Love toys's Avatar
Default help too, can't get oil pan to budge
are these 2 the ones that are at the back of oil pan pointing towards the ground? the ones "how to" says to lossin up? cause i can't get mine to move either, took 10 off and then these 2 backed way off make twelve. it won't budge, it will try to move but something seems to be holding it, i don't think it's the seals cause it moves a lil
Old Jun 2, 2010 | 07:09 PM
lol nvm, took a break went back and it was so obvious, feel like a dumb ***. oh well sometimes u gotta step away for a min. lol
