Found this on my drain plug, pics inside
Old Mar 8, 2010 | 08:48 AM
ls1muscle's Avatar
Default Found this on my drain plug, pics inside
So I was changing my oil and found a few pieces of metal on my drain plug. Anyone know what this is?
Old Mar 8, 2010 | 09:54 AM
mikefirehawk0623's Avatar
does not look good
Old Mar 8, 2010 | 09:58 AM
redbird555's Avatar
Looks like u puked a rocker arm or two not usually a big deal just take the rocker arms off till u find the one(s) that are missing some needle bearings and replace. Those dont look like pieces of a bottom end bearing or anythingt.
Old Mar 8, 2010 | 10:06 AM
Mike454SS's Avatar
I agree...doesn't look like any type of bottom end part...I'd do what he mentioned above...and then depending on what I find in there, I'd take the oil pan off if necessary to find the remainder of the parts, as well as to make sure the oil pump pickup is clean and in good shape still.
Old Mar 8, 2010 | 10:17 AM
Mike454SS's Avatar
...plus it's worth cutting the new couple oil filters open just to make sure that you're not collecting any post damage glitter.
Old Mar 8, 2010 | 11:36 AM
Z284U2TRY's Avatar
not knowing what is done to your car I am going to say spring.
Old Mar 8, 2010 | 11:54 AM
00pooterSS's Avatar
Those look like possible smashed rocker arm roller bearings, but I didn't think they normally got smashed?? I had a similar issue when my valve springs started breaking but looked a little different than that, here are what my springs looked like
Old Mar 8, 2010 | 01:31 PM
PAGregSS's Avatar
Looks like the pieces of the side of the rocker arm, not the bearings themselves. I bet if you pull the valvecover off, you'll find the bearings laying in the head or down the pushrod holes.
Old Mar 8, 2010 | 01:48 PM
98PurpleT/A's Avatar
X2 check the filter
Old Mar 8, 2010 | 07:18 PM
SweetS10V8's Avatar
I agree, looks like a piece of valve spring or rocker arm trunion piece to me. I would drive it anymore until you figure it out.
Old Mar 9, 2010 | 03:19 AM
LilJayV10's Avatar
x2 on the valve spring. I found the same thing in my engine and haven't taken it apart yet. It looks like the very end of the winding on the valve spring, the part that sits on the head.
Old Mar 9, 2010 | 04:29 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
atleast its a fairly quick process to remove the valve covers.
Old Mar 17, 2010 | 06:43 PM
ls1muscle's Avatar
I pulled the valve covers and looked at the rocker arms & valve springs and didn't see anything wrong. I'm going to go ahead and take off the rockers and inspect them and then do the trunion upgrade.
The car makes power, revs high, and doesn't make any noises. I don't know what else to look at without further dis-assembly. It looks like a top end piece, not bottom end.
Old Mar 17, 2010 | 07:23 PM
DaddySS's Avatar
check your valve springs closely, looks like a broken piece of spring to me.
Old Mar 18, 2010 | 06:56 PM
ls1muscle's Avatar
I inspected the rest of the valvetrain today and found the problem. A few of the inner valve springs are broken. This is on a AFR 8019 dual spring.
Old Mar 18, 2010 | 07:02 PM
pauls99z28's Avatar
wow! what lift cam you do you have?
Old Mar 18, 2010 | 11:20 PM
ls1muscle's Avatar
.645" on the intake.
Old Mar 19, 2010 | 12:38 AM
LilJayV10's Avatar
Really?
.645?
It's a valve spring.
Old Mar 19, 2010 | 05:36 AM
bjamick's Avatar
I see you're in Bham, I am here to. Guess I've never seen your car out and about, I think I would remember a big cammed ls1.
