Katech C5R chain
Old Mar 11, 2010 | 01:25 AM
355TurboLT1's Avatar
Default Katech C5R chain
Will the rollermaster single gears work with the C5R chain. I do not want to use my old LQ9 gears.
Old Mar 11, 2010 | 02:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Do you already have the katech chain or the rollermaster gears? I dont see why they wouldnt work. The other alternative is the LS2 chain or timing set. It works on the same applications.
Old Mar 11, 2010 | 04:25 AM
vettenuts's Avatar
Not sure on the Rollmaster, however I tried it on the JP Performance gears and it was not smooth and didn't feel right so in the end I didn't use it. If you don't need adjustability I would use the stock gears. If you do, Katech used to recommend the Cloyes setup with the chain.
PS::Rollmaster is owned by JP Performance but not sure if this would yield similar results as to what I found.
Old Mar 11, 2010 | 04:29 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are all those gears, minus the doubles, generally the same thickness? Mine felt just like the stock one did. hmmm.
Old Mar 11, 2010 | 11:45 AM
Does anyone know where I can get a cloyes single setup for the LS1/2? The C5R chain was ordered yesterday so now I need to find some gears. I know the stock ones will work but I would prefer billet gears if I can find a set that match as well as the stock LS2. Thanks
Old Mar 11, 2010 | 01:16 PM
vettenuts's Avatar
Cloyes has them and any vendor who sells their products with have it. The Cloyes Hex-adjust comes with the LS2 chain, which you can sell to recoup some of your money.
Old Mar 11, 2010 | 03:39 PM
XtraCajunSS's Avatar
The Comp LSx timing sets are re-boxed Cloyes Hex-a-just sets. I normally have them in stock. Let me know if you need one.
Thanks,
Shane
