TR220-114 in a 6.0.
If my understanding of cams is correct, a cam that acts one way in one engine, will be a little more mild in a larger displacement engine.
Will that difference be all that great if I'm only going up a third of a liter, to a 366" motor?
Where can I expect peak power to be? (I didn't catch any dyno's on this cam)
Finally, what intervals are you all using on valve-spring changes for these smaller TR cams?
Thanks
I was originally really leaning towards the 212/218 lower lift Comp Cam, or the high lift version, but wasn't keen on the 115 LSA or the "Good LS6 replacement" statement there. I think it's on the higher side of things for a truck, but.........
Yeah, the cam won't go in until I have Edit and Autotap or EFILive handy... I hope Carputing can get the in-car programming working by late Winter here. I'm not too keen on having to buy the seperate bench cable and doing that routine.
What size cam are you running right now?
My cam is on a 114 lsa and if I had my choice, I'd have it on a 115. I don't think you'd lose power with the 115 over the 114, just smooth out the idle some.
From what I've read people have said anywhere between 12000 to 18000 miles for a valvespring change. What mods have you done to your engine? The MTI Stealth 1 is a 220/220 ~.580/~.580 115 -- Would you be looking for something like that? It's one I'm still considering.
I hear you on the peak numbers... I'm trying to avoid that too, although I do feel like I'd be making SOME comprimise with a TR220. I'm a real sucker for a lopey cam, so I thinking this would be a decent comprimise for me.
What did you end up with for an idle speed?
Thanks TA98.
I don't have any mods just yet. Well, I've got an intake (tube and lid) hanging around that needs some repairing.
A cat-back exhaust is in the works. Not sure which way I'm headed though. Custom or $750 brand name setup.
Headers will be coming, I just need to check MA laws to see if I can run mid-length tubes. (No cat relocation, but need mods to Y-pipe) I don't believe there are any true long-tubes for trucks.
I'm still up in the air about a stall. Either a 2600 or 3000. I tow, so I'm limited to those two choices. I'll have to see how serious I end up getting with things, or how big of a lowend hole the cam makes.
The cam is the only thing I'm really sure on at the moment, so it'll be the first serious mod to go into the motor.
