Please help with CAM choice
Old Mar 16, 2010 | 10:14 PM
Vertigo's Avatar
Default Please help with CAM choice
Car is a 99 Pont GTP with M90 Blower with a 3.0 pulley pushing about 10lbs boost. Looking to see which one will not bleed boost and make better power over a wider part of the powerband.
Cam 1: VS cam
206/216 at .050"
Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
115 LSA
Cam 2: S1X
duration @ .050": 210?/221?, lobe lifts: .321"/.329", valve lifts with 1.60:1 rocker arms: .514"/.526", lobe separation angle: 115?, intake centerline: 111?
