rod bolt question?? please help.
Old Mar 17, 2010 | 07:08 PM
Noyzee's Avatar
8 second mod
Default rod bolt question?? please help.
i have searched this for 2 days and read a lot and just cant get a 100% correct info, i read the pro series arp rods are fine, then i here they need work, the regular ones are fine, the pro are ok people just dont know.
please tell me will the bolts i have go right in if i remove the sleeves in the rods.
arp part# ls pro 2346301
Old Mar 17, 2010 | 10:50 PM
KCS's Avatar
KCS
Moderator
Did you try calling ARP? I'm sure they would know.
Old Mar 18, 2010 | 07:09 AM
outkast6991's Avatar
i was told by Ed Curtis that ARP bolts all require work on the rods. Katech is the supposed to be the only "drop in" replacement bolt
Old Mar 18, 2010 | 03:05 PM
Noyzee's Avatar
8 second mod
****, im told 3 different things. prob just going to order the other ones
Old Mar 18, 2010 | 08:24 PM
99T/AMAN's Avatar
i have read both but i a, going with the katech's, made from the same place and same specs as the stock bolt just alot stronger!!!
