oil pump problems
Old Mar 20, 2010 | 04:31 PM
crazygn's Avatar
Default oil pump problems
Is there a way to rebuild these pumps, i have a 1000 mile ported ls6 that wont pump over 25 psi
could the guy that ported this thing maybe put it together wrong or should i just trash it
Old Mar 20, 2010 | 04:43 PM
brian_rs/ss's Avatar
buy a melling hv pump. they aren't that expensive. i have one and absolutely love it.
Old Mar 20, 2010 | 06:19 PM
SOMbitch's Avatar
How do you know it is the pump??? old o ring on there?? pinched o ring?? pick up tube slipped?? Check these before you trash the pump.....
Old Mar 20, 2010 | 07:26 PM
crazygn's Avatar
i just put my stock pump back in and it has 30psi idle and 33psi on the gas. this will be the 3rd time apart now. I'll hit the dealer monday and get 2 blue o rings. what do you mean by slipped pickup tube. Has to be something dumb because the stock pump worked fine , a little slow on startup but worked. I only did this so i could put a duel roller chain on.
is there any gaskets or seals in the pump that can go bad or just teh pickup o ring
Old Mar 20, 2010 | 09:08 PM
Mrs.Nos's Avatar
That is what i was going to ask
