Piston Pin weight difference
If they are all the same diameter, I would call the manufacturer and find out what's up. They should not vary much at all in terms of weight (definitely less than 0.5 grams).
LAstLS1: Why does a machine shop have to balance the pins you ask? When a 700 plus HP motor is on the line, all should be on par. Any part not perfectly weighted will be ground accordingly. Down to the bolts. Lots of mallory is likely needed anyway due to the super heavy duty rods (direct from Childress).
The pins are all the same diameter. Thanks for the valuable info though Jason. I assume the manufacturer will replace 4 of the 8. They are closed till monday, and I just wanted to know if this was uncommon...and i was gonna be bitchin about a usual discrepenancy. I do learn as I go, seems to be the most fun and educational.
