Reusing stock main cap bolts?
So... by the time this thing is ready to go into the car, my main bolts will have been torqued 3 times, plus of course their original torquing prior to my tearing the motor down. Safe, or buy new?
Then again, I suppose new GM bolts are a cost effective alternative to ARPs... and I could just use them for final assembly, using the originals for everything else. Opinions?
You'll need to swap the side saddle bolts with a set of new ones though (The small 10mm headed ones). They generally aren't re-usable. They are, but you'll at least need to put some sealant on the back side.
As for rod bolts... my new rotating assembly comes with ARPs.
Do you happen to know the GM part number(s) for the main cap studs & nuts? If they aren't too expensive, I'll grab a set for my final assembly.
That is true.
Sounds good.
Guess I'll just check at the dealer next time I'm there.
