Transmission trouble
Old Mar 25, 2010 | 10:19 PM
vetteboy99's Avatar
Default Transmission trouble
Almost everytime I drive the firehawk the transmission does not want to get into second gear. For it to get in second gear i have to move the shifter left to right like 5 times in neutral and it gets in. Not easily. Whats wrong. Does it need a new trans? Or is there something stuck in gear.
Old Mar 25, 2010 | 11:41 PM
lmt0705's Avatar
besides that, could use a little more info. does it get stuck in the gear? does it ever pop out? grind? Id be looking tword clutch or master first. its possible theres a problem with the strut keys or blocker ring but I think you would have more symptoms.
Old Mar 27, 2010 | 12:52 AM
vetteboy99's Avatar
Really Ima mechanic for like 5 years but I've never seen this. I asked my dad he started the buisness he said that it might need gears. It grinds ALOT when trying to get into other gears, but in second gear its hard to get in to. Should I replace the gears. I wanna put some 4.56 gears in it anyways. Or should I replace the clutch.
Old Mar 27, 2010 | 03:31 AM
jpajkos's Avatar
Have you checked out the throw out bearing? How many miles on are on the clutch? What type of clutch do you have? Any aggressive driving? Burnouts? Missing gears when racing?
Old Mar 27, 2010 | 10:26 PM
vetteboy99's Avatar
The car is bone stock. I haven't chec
ked anything out yet. I believe the clutch was on the car its whole life. The car has 90k Miles and hasn't been raced.
Old Mar 28, 2010 | 01:23 AM
jpajkos's Avatar
Stock clutch = No bueno
Old Mar 28, 2010 | 12:02 PM
vetteboy99's Avatar
but now its hard to get into 1st gear. Its slipping alot.
vetteboy99's Avatar
Old Mar 28, 2010 | 03:56 PM
lmt0705's Avatar
sounds like a clutch or hydrolic issue, trans might also need syncroizer hubs replaced along with new blocker rings. If your pulling the trans to replace the clutch I would crack it open and see what it looks like while its out. there not that hard to rebuild. If your a mechanic you will fly thru it easily
Old Mar 28, 2010 | 06:09 PM
vetteboy99's Avatar
I know how to rebuild a trans but doin it to a 6-spd is hard
