Would this cam work for an auto with a stock stall?
Old Mar 26, 2010 | 07:35 PM
photoman9988's Avatar
Default Would this cam work for an auto with a stock stall?
I want a better cam, and was wondering if this would give me any problems. I have a 2000 WS6 with a stock A4, stock stall.
cam specs are
226/229 .575/.578 112LSA
Old Mar 26, 2010 | 07:52 PM
rgriffin's Avatar
Why not do the stall instead?
Old Mar 26, 2010 | 07:53 PM
KevinR's Avatar
Man, I wouldn't do it. You may want to start with exhaust and a converter first. This is just my opinion.
Oh yeah, and gears
Old Mar 26, 2010 | 07:57 PM
Oh yeah, and gears
I already have full intake and full exhaust.
Old Mar 26, 2010 | 07:59 PM
KevinR's Avatar
Ahhh.. I would do a converter first.
Old Mar 26, 2010 | 08:01 PM
Well I'm eventually going to get a 3600 stall, but I was wondering if it would WORK with the stock one.
Old Mar 26, 2010 | 08:02 PM
KevinR's Avatar
Sure it would. But it would suck.
Old Mar 26, 2010 | 08:18 PM
1969mach1's Avatar
get the cam, and put in up on a shelf till you get the stall.
Old Mar 26, 2010 | 08:19 PM
98z8uup's Avatar
Get a stall.
Old Mar 26, 2010 | 09:11 PM
camz28arro's Avatar
It would suck, I drove around for a year with only a 224/224 .563/.563 114 on the stock stall and hated it. Thatcam would make the car feel like it always has a cruise control set on, use more gas trying to stay at idle, and from a stop without any gas the car would shift to 2nd. You could lower the idle to 650rpm but then it will stall getting off the gas on a gear shift or when starting a warm engine. Definately do a converter first.
Old Mar 26, 2010 | 10:11 PM
Paint_It_Black's Avatar
If I had a stock A4, the first mod would be a stall.
Old Mar 26, 2010 | 10:20 PM
lemons12's Avatar
I love having a car sound mean as hell but run like ****...
Converter first, period.
Old Mar 26, 2010 | 10:30 PM
Damian's Avatar
LSX Mechanic
To answer your question, no. That cam will more than likely try to walk through the stock stall and pull on the brakes. Anybody even considering camming a car w/ a stock stall should be looking in the lower 220's in duration, with nothing below a 113-114 LSA.
In closing, I'll add that I agree with everyone else. Put a stall in the car first.
Detoxx03's Avatar
You can do whatever you want but that doesn't make it right. I don't know why newbie's insist on getting a cam in their A4 w/o the stall first or at the sametime. Do the stall first or buy the cam and wait to install it until you have the stall.
Old Mar 26, 2010 | 10:36 PM
lemons12's Avatar
All that matters is the sound bro...
Same reason everyone wants an Ms4 cam and wants to have good MPG and run 373s 3500 converter and stock intake/heads. !!!!!
Old Mar 26, 2010 | 10:38 PM
ok, what if i got a 3000 stall for now. would that be enough?
Old Mar 26, 2010 | 10:41 PM
lemons12's Avatar
Would it be enough? Yes...
I would recommend a minimum of a 3400 though on ANY setup. Even a stock to light bolt on car.
The difference under normal acceleration/DD would be minimal to non existent, under WOT there would be a big difference.
Old Mar 26, 2010 | 10:42 PM
lemons12's Avatar
FWIW... I have a 226/228 .588 114 cam, I also have a PTC 4000 converter.
Old Mar 27, 2010 | 12:10 AM
if i got a 3400 stall, would i need a tranny cooler? if so, how much are they, And about how much to install?
Old Mar 27, 2010 | 12:16 AM
02*C5's Avatar
I am doing a dual cooler set up on a vigi 3400 stall and she stays very cool. But yes do a stall that should have been your first mod on an A4.
