Swap in bigger cam for 15-20rwhp?
to a comp 232/234 112 with .598 lift
+ a 10% u.d. pulley, and a ported throttle body and gained 34 hp and 4 ft of tq, but the tq curve was also much longer..
So theres always room for improvment, in my case my first cam had a realy low lift...
Looking back now I wish I went with a custom grind, but either way its a huge improvment over my first baby cam, it just didnt have enought lift.
Heres the dyno sheet comparing the two, the bottom line is the old 220-224 cam, then top two lines are new cam numbers (one is with cutoutclosed other is with it open)
Im glad I did the switch, cause I spent 250$ on a new cam vs $1500 for a set of heads or $1000+ for a fast. Plus I didnt think id gain as much as I did from just a bigger cam.
But if you on a budget a better cam will make alittle more , and is definatly worth it if your doing labor yourself.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
To be honest, LSA is a byproduct of the valve events that went into creating the right cam. That approach is tough to grasp and tougher to market. Nearly all vendors offer the standard 110-112-114 line up because that is one of the three things 95% of consumers know about camshafts.
i agree so many cars take their cams to the point where they enter saturation, id rather be on the lower end in the efficient region. at the end of the day no one really cares how big it is. lol
Prc 5.3l 59cc stage 2 heads
fast 90
ls2 tb
longtubes with offroad x-pipe
slp Pulley
30 pnd injectors
ls7 clutch
i should complete the cam swap on saturday and take car for tuning next week. ill post results and numbers.
Thanks for those graphs Jason, looks like both the 224 and 228 cams made 465hp at the 6200rpm range and since I'm staying under 6200rpm, the cam I have now is fine, I wish I could just figure what to do about this crappy 10 bolt now.
