Enlarging header bolt hole in head
Old Mar 29, 2010 | 03:36 AM
Armageddon's Avatar
...with cheese.
Default Enlarging header bolt hole in head
I also posted this in external because it seems like it could go either way.
I'm tired of these 8mm header bolts. Every set of heads I buy have atleast half of the 8mm header bolt holes coiled. Coils hanging out a thread, or somehow the coil is rolled over and won't thread... The uncoiled holes barely have thread in them... I'm sick of it.
My question is: Is there any reason why I can't coil it to 9x1.25 or even 10x1.25/50. Is there enough meat to safely do this? Or do I need to fight with these old 8x1.25 coils and put new coils in the uncoiled holes...
Thanks
Old Mar 29, 2010 | 04:54 PM
Pocket's Avatar
Helicoil it to whatever you please. There is tons of aluminum there to go through
Most bolts are stripped from overtorquing, rather than issues with the bolts
Old Mar 29, 2010 | 07:28 PM
RARON455's Avatar
there is also something else besides a helicoil, called a keensert, we use them at work on our equipment, You drill the hole out and tap it then thread the insert in and knock the locking tabs that are on it in, it is made out of steel, so no more stripped aluminum.
Old Mar 29, 2010 | 09:27 PM
Armageddon's Avatar
...with cheese.
That sounds exactly like a heli-coil to me. Maybe a different manufacturer?
Old Mar 29, 2010 | 09:28 PM
Armageddon's Avatar
...with cheese.
Thanks for the reply.
