How often should you change your Comp 918 Springs?
Old Jan 4, 2004 | 01:01 AM
MUSTANGEATER's Avatar
Default How often should you change your Comp 918 Springs?
Just what the title says looking for a general rule of thumb have about 5-6k on mine and was wondering how much longer until I should change them out?
Old Jan 4, 2004 | 01:38 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Depends on the cam and how hard you are on the valvetrain.
Some people with more mild cams like mine (B1) have 30K+ street miles with the same set.
I don't even plan to think about changing them till 30 or 40K, and maybe not even then. Under the conditions that I use my car and with my setup, I could probably get over 50K on the same set.
Obviously though, intervals will very with setup and usage...
Old Jan 4, 2004 | 03:25 AM
Jabroni's Avatar
13K on mine. If you aren't lifting to the moon on an XE-R cam, you should be able to get at least 20-25K on them with little track time and a mainly street driven car. My cam's a 222/222 .566 and so far so good.
Old Jan 4, 2004 | 07:48 AM
Fireball's Avatar
gonna start changing mine annually.
broke one at the thunder shootout with ~20K miles on it
232/232 .574/.574 112 XE cam. Not terribly hard on springs
Old Jan 4, 2004 | 08:04 AM
VINCE's Avatar
Shorty Director
I think annual is a good rule of thumb for cams near 230. For cams over 230 you might want to go to duals or change springs every 7 to 10 months for peace of mind.
Old Jan 4, 2004 | 09:12 AM
John02SS's Avatar
I'm running a TR 224 and will probably change them around 12-15K just for the Hell of it. That is if I can keep from doing heads and a larger cam!
Old Jan 11, 2004 | 09:15 PM
IrateTA's Avatar
Stupid question - but how can you tell when the springs fail, or become weak (in the case of a spring not actually breaking)? I know that valve float is one of the consequences, but is there a change in sound? Loss of power? Pieces of the engine coming out the exhaust tips?
Old Jan 11, 2004 | 09:23 PM
WS6MB's Avatar
for you guys that break, what RPM are you going to and do you think that makes a difference. I rarely go over 6500.
