Need a little with combo?
Old Mar 30, 2010 | 08:14 PM
Kris Mangrum's Avatar
Default Need a little with combo?
I come from mustangs. I know the lingo and know some pretty reliable 302 351 combos. But I know very little about the 350 engines. As far as what works with what and whats best for a budget. I will be getting a wrecked 2002 corvette sat the 10th. The motor is stock and only has 33k on it. I understand that they come with 350fwhp.
My goal is at least 400 rwhp and the more the better. I am on a pretty tight budget because I'm building a FFR GTM kit car and need to save the money for it. The car comes with special made exhaust so I can't change that.
I have put this together just from reading a few days. What kind of power would it yield me. Thanks in advance. Kris
2002 ls1, with used ls6 heads, mail order tune, and what ever cam you guys say I should use.
Old Mar 30, 2010 | 08:32 PM
xxBlackTAxx's Avatar
If you're going to get stock unported ls6 heads then i would keep the cam in the low 230s. I have a 99 trans am and i am going to be getting a tsp228r cam to use with my stock heads but when i get ls6 heads i will probably go with something around 232. goodluck with the car man
Old Mar 30, 2010 | 08:47 PM
garygnu's Avatar
check out the dyno section .some good threads on ls6s and EPS cams.
Old Mar 30, 2010 | 10:01 PM
You have contact info for EPS?
Old Mar 30, 2010 | 10:10 PM
Josh18Fan's Avatar
http://www.engpwrsys.com/
They've made some pretty insane power with stock ls6 heads and their custom cam lobes.
garygnu's Avatar
Engine Power System ,225-751-8500,or PAT-G.they are a vendor listed on the right.
Old Apr 1, 2010 | 02:42 PM
'02 WS6's Avatar
X2 on Geoff @ EPS and Pat G. ]at G spec'd my cam, and Geoff took care of the rest.
