pushrod length
Old Apr 2, 2010 | 09:15 AM
hifi875's Avatar
Default pushrod length
have a 5.3 stock motor w/862 heads. changing over to 243s milled .030 w.040 head gaskets. have stock lifters and rockers w/a ls1 cam. will i need different length rods? if so, what length.
Old Apr 2, 2010 | 10:27 AM
RARON455's Avatar
You are more than likely going to need new ones, due to the milled heads, the only way to be sure is to measure for correct pushrod length using a measuring tool. People can guess but no guess is exact it is still a guess.
Old Apr 2, 2010 | 10:44 AM
TechCam97's Avatar
You can check at a local parts store for a rod length checker tool. It was like $20 to $30 last I checked.
Old Apr 2, 2010 | 11:14 AM
hifi875's Avatar
ok thanks!!
Old Apr 2, 2010 | 08:51 PM
Bill'sWS6's Avatar
My Guess Is 7.375
Always Check....Pre Load Should Be About .080
Good Luck!!!
