Compression questions
Old Jan 5, 2004 | 05:29 PM
NataSS Inc's Avatar
Default Compression questions
12.5:1 domed piston with Stage 2 LS6 heads that have been milled .030. what would the final compression come to? On an unmilled head that would be around 13.7:1. What would the jump be on the milled head.
I am a complete tard when it comes to trying to figure out what that kind of stuff works out to.
TIA.
Old Jan 5, 2004 | 06:14 PM
Cal's Avatar
Cal
I could figure that out if you know how many the CC's the Stage 2 LS6 heads have before milling them. It will be higher than 13.7; that sounds like too much compression unless you're going to burn race gas or alcohol.
Old Jan 5, 2004 | 06:17 PM
NataSS Inc's Avatar
Got me on that one. Let me do a little looking around
Old Jan 5, 2004 | 09:47 PM
DaleMX's Avatar
Well the PP site says stage 2 LS6 = 64.45cc
Old Jan 6, 2004 | 09:50 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds like a motor that will need to run on 110.
Old Jan 6, 2004 | 10:03 AM
critter's Avatar
This is more or less on topic ...
A friend called last night to tell me about a (new?) Torco additive (they do not call it an octane booster) that is supposed to be the concentrated additives they use to make racing fuel. The treatment is 1 quart to 16 gallons, giving 103 from 93. 2 quarts gives 107, which they say really acts like 110. Don't quote me on the numbers, please. You can mix less also. The cost is ~$56/case of 10.
Is this old news? Anybody have any experience?
Old Jan 6, 2004 | 11:00 AM
NataSS Inc's Avatar
I dont like mixing fuels, On a high compression motor I have never wanted to risk the chance of not putting the right quantities in the mix. I'll just stick to the 55ga drum of VP.
