motor build up help
so ive been switching what i want to do with my motor alot now due to budget. now the plan is to do a 383 with some spray. here is what i came up with so far. il probably spray a 200 shot on this and have 42# injectors and a racetronix fuel pump kit
383 forged rotating assembly
ms4
ls6 intake
1 7/8 lts and ory
243 heads
how much power would this combo get me? i know it will be more then the 390 i made wit my ms3, 853 heads and 1 3/4 lts. also would anybody reccomend a different cam. id like it big and choppy so i figured the ms4 would be great since i loved my ms3. also what piston size should i go with? i have 93 octane gas in my neighborhood and would like to get it as high as i could thats easy to tune on pump gas.
ms4
ls6 intake
1 7/8 lts and ory
243 heads
my goal is to make 425 at the wheels on the motor. is this possible? i was looking at the megadeath cam also? would this be more choppy then my ms3? how do you guys like this cam?
check out GMHTP website. search "my first stroker". Chris Werner did a great write up. It's a four or five part article. You should get that power no problem. Good luck and post when you are done!
