Thoughts? Time for a bigger cam...
Old Apr 13, 2010 | 06:50 PM
Squirts11's Avatar
Default Thoughts? Time for a bigger cam...
Time to upgrade the goods!
Currently have a custom PatG spec'd cam (219/227 .600ish lift) made specifically for the STOCK torque converter. It did an excellent job at what is was designed to do, as it gained power literally everywhere and picked up 45rwhp and 26lbtq.
Two months down the road and I've purchased a 3600 stall and am in the market for a bigger cam (I initially thought I'd be done modding after the cam...riiiight ).
After talking to multiple members, sponsors, etc, I think I've decided to go with something along the lines of a custom 228/232 .600ish lift 111-113 lsa (hasn't been spec'd yet so I'm not positive on the details exactly).
Just wondering what your thoughts are? I think it's a great power/price ratio considering I'll be able to keep my hardened 7.425 pushrods and basically new Comp 918 springs (only 1k miles w/ supposedly new design that is good for .625 lift, but who knows).
With the 3600 stall I figure this seems to be a fairly good setup for a daily driver that likes to run whenever given the chance. As always, I think there are a lot of knowledgeable people on this forum, and I'm absolutely open to opinions/comments.
Old Apr 13, 2010 | 07:37 PM
Justus67's Avatar
I like the TSP 228R, good power under the curve and smooth idle with the 114 lsa. If you want the choppy idle 112 lsa or lower. Also the TR230 is nice for dd power and streetability.
Old Apr 13, 2010 | 11:05 PM
Squirts11's Avatar
I considered both of those cams, particularly due to the great under-the-curve area they provide, but I want a bit more out of my next cam and would prefer whatever I decide big enough satisfy my hp needs longer than two months lol.
That's why I'm opting for something that is still very streetable with the right tune and my setup (3.73s, 3600 stall), and will be a worthwhlie gain for the money of a new cam.
Anybody else have thoughts on a different set of cam specs?
Old Apr 13, 2010 | 11:38 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
If you like your current setup I'd return to Patrick G and have him spec you something more along the lines of what you are looking for now.
Old Apr 14, 2010 | 12:53 AM
SOMbitch's Avatar
Yeah talk to Pat and seriously look at the new EPS lobes. I don't have any personal experience with them but from what I have read on here guys are having great luck with them. I am gonna look at them hard when I can finally do my LS2 402...
Old Apr 14, 2010 | 12:55 AM
Squirts11's Avatar
Actually, the cam I have now was made by Geoff at EPS using the lobes you mentioned. The high-rpm stability, good power, and reduced stress on the valvesprings made them an appealing choice.
Old Apr 14, 2010 | 06:53 AM
mark21742's Avatar
Kind of off topic, but since you already have the cam, have you thought about keeping it for awhile and upgrading to a great set of heads?
Old Apr 14, 2010 | 03:22 PM
Squirts11's Avatar
Yeah, but it is much more appealing to get a 400 dollar cam when I'm able to reuse my pushrods, springs, etc. Especially since I'll be able to sell the cam I'm currently running to recoup some of the expenses.
For the hp gains, the price/gain ratio is fantastic. Heads might have to wait a while.
Old Apr 14, 2010 | 04:27 PM
mark21742's Avatar
Ok, just throwing out the option, heads are the only thing left on my list. Lol I have a hard time shelling out $2,000+ right now so I know what you mean
Old Apr 14, 2010 | 04:33 PM
Paint_It_Black's Avatar
Why quit going with what works? You seem so happy with your current cam. Call Geoff directly, he is one of the few people who really know how to spec cams for these cars. Just tell him what you have, what you upgraded, and where you want to go.
Old Apr 14, 2010 | 10:59 PM
Squirts11's Avatar
Geoff @ EPS mentioned something along the lines of a 226/334 .600ish lift on 113ish.
What are everyone's thoughts on those specs (a rough estimate of what the specs are) compared to the 228/232 I mentioned earlier?
Old Apr 15, 2010 | 02:46 AM
I'm sure Geoff has that on a +2 and you meant to type 226/234
That is a great suggestion. My dyno software likes it a little bit better on a 112+2, but that should give you a very very fat torque curve, and peak just over 6000 rpm but carry well to 6500.
Old Apr 15, 2010 | 05:10 AM
PRE-Z06's Avatar
Nice gains with the original cam, what lsa was it on and how much are you looking to gain with the new cam?
Old Apr 15, 2010 | 10:17 AM
Squirts11's Avatar
Yes, I meant 226/234, as I suppose I'm not quite ready to go with a 300+ duration yet...
It's on a 115+4, but still has a decent chop at idle (surprised me actually), since the idle speed was kept low (550rpms). I'd like the new cam to make it worth my while to swap, maybe 20-25hp? Does that seem unreasonable with the two cam choices I've mentioned?
Old Apr 16, 2010 | 05:11 AM
PRE-Z06's Avatar
I'm guessing 15hp, 20 is gonna be stretching it IMO
Old Apr 16, 2010 | 06:35 AM
Nitroused383's Avatar
Honestly you're not going to gain much at all from a 220 duration cam to a 226ish duration cam. 5-10 hp would be my guess. To gain 20-25hp you're better off keeping your current cam and getting a set of better heads, which could gain 20-50hp.
Old Apr 16, 2010 | 06:42 AM
Squirts11's Avatar
I'm not planning on the 226/234, that was just a suggestion I got yesterday. I'm going to look at a local set of 243s this weekend that are listed very reasonably. If they're in good enough shape, I'll pick them up and mill, get a decent vj, bowl blend, and port the runners. After getting the flow numbers I'll have a new cam spec'd.
I'm still wanting something that's going to produce a lot of area under the curve, generally the flatter the torque curve, the better. At the very least I'm leaning towards something around 228/232 .600ish lift 111-112.
Old Apr 16, 2010 | 01:10 PM
I'll make my recommendation public..
230/238 110+2 on EPS lobes.
Remember you have to work with the comp 918's you have, and those would need to be shimmed for those lobes. Anything more aggressive like an XFI or LSL and you are going to have to upgrade to duals.
Old Apr 16, 2010 | 01:55 PM
Squirts11's Avatar
Ooooo, that sounds tasty. I know that'll pull hard up top and sound like it's pissed off. I guess a big concern would be PTV issues since I plan on milling and/or using thinner head gaskets.
Old Apr 23, 2010 | 01:56 AM
PRE-Z06's Avatar
The XFI lobes were intended for the new 918 springs, I run them with my set-up...230/236 XFI 113+2 imo if you're milling the heads to bring static over 11:1 and the wider lsa will flatten the torque curve
