need help with piston size!
Old Apr 17, 2010 | 09:08 AM
00 black ss's Avatar
Default need help with piston size!
im building a 383 with stock 243 heads. i want it to be pump gas friendly so what would the max compression ratio need to be? im going with a big cam like a ms4 or the eps 238/248 cam. what size piston should i go with? i want to stick with wiesco or diamond since i am going to be spraying it. thanks in advance.
Old Apr 17, 2010 | 11:58 AM
brooknasty's Avatar
From what I read and hear an ls1 block can only be bored out to .100 safely. and compression no higher than 11.5
Old Apr 19, 2010 | 11:48 AM
white84z's Avatar
Do NOT have your block bored out .100, that will ruin a perfectly good block. Most 383 kits end up in the 11.3-11.7 compression ratio and run a 3.905 bore.
