Smoking like a B*tch- help
Old Apr 23, 2010 | 07:26 AM
adam120674's Avatar
Question Smoking like a B*tch- help
I have a 99 z28 on Passeger side exhast I have white smoke coming out when I'm on the gas. Also have smoke coming out of Passenger head or Erg line I can't tell. Drives rough as hell at 55-65, but not bad as I accellerate. No water in oil. Any Ideas on the most likely cause? I'm not very motor savy , would like to install a 408 stroker but I do not have the money, may just have to fix what I got
Old Apr 23, 2010 | 09:16 AM
Ryneman's Avatar
How many miles on the engine? I would replace the exhaust manifold gaskets and your EGR gasket (if you haven't already blocked them off).
If that does not fix it, I would take it to a good exhaust place and have them check the system for leaks.
That is the cheap first step to fixing your problem....my .02
Old Apr 23, 2010 | 09:56 AM
prochargedpony's Avatar
It sounds like a blown headgasket to be honest, I would do a block test. You can get them at autozone/napa. Just because no water in the oil or vise versa doesn't negate it not being a headgasket.
Old Apr 25, 2010 | 10:21 AM
adam120674's Avatar
Ok , don't think it's the head or head gasket. PCV line was loose and the smoke was pouring out of that once it got hot causing a huge vac leak. Also getting no back pressure coming out of my radiator. Before I hook it back up should smoke be coming out of this line . If not what does it mean rings bad?
Old Apr 25, 2010 | 10:44 AM
1NASTYZo6's Avatar
I would say withwhite smoke it can only be one thing! Water getting into the combustion chamber. How its getting there is difficult sometimes to figure out. Just because the water is not in the oil does not mean its not a head gasket. The gasket can blow between cylinders and this might not make it in tho oil passages. Also the leak could be small enough that it would not presurize the coolant system. this as a result would not change the coolant level that much either for while. I have see this happen as well.
My .02
Old Apr 25, 2010 | 02:22 PM
NHRAFORMULA00's Avatar
Yes i agree,if you have continious white smoke,you have a bad head gasket. The coolant is being sucked into the combustion chamber past the head gasket.
Old Apr 26, 2010 | 06:05 AM
adam120674's Avatar
ok, but smoke coming out of the Pcv line, would that indicate I have bad rings or something allowing the smoke from the head to pass to the bottom of the block.
Old Apr 26, 2010 | 09:24 AM
Dskeet6's Avatar
yes.... some of the smoke gets past the rings and goes into the crankcase... then vents out of the pcv
Old Apr 28, 2010 | 08:10 PM
adam120674's Avatar
Ok, took the head off today. I found a bent pushrod, everything else looked good. Possable it was just over reved and done no more damage to anything?
Old May 6, 2010 | 04:34 AM
adam120674's Avatar
Ok , replaced head gasket and pushrods with chromoly pushrods. Cranked up , liked like the car was on fire!!!!I saw oil getting pushed out on my turbos exhaust side. Going to unhook turbos to make sure seals in turbos are not bad. Then about 10:00 that night I remembered something. While I had the heads off, I poured some oil on top of my pistons, thinking that if I had some bad rings it would leak down. I rotated the engine to push the excess oil out over the block when I was done. I thinking this is what causing the smoke. As I said in the first post, I'm not very motor savy. Is it Ok to just run the car and let it burn it off or do I need to do something else?
Old May 6, 2010 | 04:39 AM
justin455's Avatar
Douchebag On The Tree
If it's just some residue I wouldn't worry about it. Let it fun for 5-10 mins and if it doesn't clear then worry.
Old May 6, 2010 | 05:11 AM
itsslow98's Avatar
We need to know your build specifically i had no idea this was even turboed until i read this post.
Old May 6, 2010 | 07:42 AM
laughatrice's Avatar
the fact that you have turbo's changes everything should have mentioned that one.
Old May 7, 2010 | 07:22 PM
adam120674's Avatar
Ok, unhooked turbos, capped oil lines. Cranked up, oil is pouring out of exhaust manifold both sides.
