LQ4 or LQ9
Old Apr 23, 2010 | 11:33 PM
99beaSSt's Avatar
Default LQ4 or LQ9
I have a 6.0L iron block out of a 01 chevy truck, got it dissasemabled, found out it has 317 heads but i cant for the life of me figure out if its a LQ4/LQ9. I called around but no luck, how can i tell?
Old Apr 24, 2010 | 12:32 AM
StrokerAce03's Avatar
If it has dished pistons it's an LQ4; LQ9's had flat tops and beefier rods for that year. Most likely it would be an LQ4 since it came out of a truck.
Old Apr 24, 2010 | 12:36 AM
99beaSSt's Avatar
Im pretty sure when i took it all apart it had flattops in it but ill check again, thanks for the speedy reply.
Old Apr 24, 2010 | 12:38 AM
1BAD_LS1 Tunes's Avatar
Yep this is correct... look at the pistons, easiest way to tell!
Old Apr 24, 2010 | 06:54 AM
SweetS10V8's Avatar
Unless it was a Silverado SS or Escalade, its going to be an LQ4
Old Apr 24, 2010 | 10:05 AM
GMCtrk's Avatar
There was no 01 LQ9. Production began with the 02 model year.
Old Apr 24, 2010 | 10:17 PM
99beaSSt's Avatar
Good to know thanks, can you tell me what the difference is in the two?
Old Apr 24, 2010 | 10:21 PM
bww3588's Avatar
what are you talking about?
Old Apr 24, 2010 | 10:37 PM
99beaSSt's Avatar
I know there both 6.0L and the pistons are different. Is there anything thing else that makes a LQ4 different from an LQ9?
Old Apr 24, 2010 | 11:17 PM
Octavain's Avatar
What he said! LQ9 was introducced in 2002 and put into Cadillac SUV/EXT, that year. They started to put them in Silverado SS in 2004.
Old Apr 24, 2010 | 11:27 PM
87silverbullet's Avatar
There is also something about the length of the crank out of the back of the motor in some of the earlier lq4's. I can't remember what years so if somebody remembers please chime in.
Old Apr 25, 2010 | 12:26 PM
bww3588's Avatar
99 and 00 had a longer crank to mate up to the 4L80E transmission. in 01 they started using the shorter LS1 style crank with a spacer.
Old Apr 25, 2010 | 09:18 PM
Avengeance's Avatar
I just ordered a 6.0L crank from GM... the solid "truck" crank. I wonder if Ill have any issues bolting up my flexplate/converter.
