Prep block after head gasket failure
Old May 1, 2010 | 12:59 AM
RyanSws6's Avatar
Default Prep block after head gasket failure
I'll be getting my heads back next week after a small mill job. I've never had a head gasket blow out. So other than a clean is that all?
I'm installing head studs with the heads and wow I had no idea studs were that much!
Old May 1, 2010 | 02:58 AM
Duffster's Avatar
clean bolt holes, maybe even thread-chase them. . . clean surfaces... (brake cleaner does well)
Old May 1, 2010 | 08:16 AM
vettenuts's Avatar
Ask the machine shop to provide you with flatness and Ra values once the heads are milled.
Old May 1, 2010 | 08:21 AM
SweetS10V8's Avatar
Hopefully your block is flat. Makes sure you thoroughly blow out your head bolt holes and clean the deck of your block.
