Help quick
Old May 1, 2010 | 09:35 PM
LS12Fast4U's Avatar
Default Help quick
Hey im doing my cam swap right now and im stuck at the timing cover. The bastard is glued on there like a mother F er. Anyone know a trick to get it off?
Old May 1, 2010 | 09:38 PM
johnster's Avatar
u do have the bolts out {rite} take a flat head and pry on it alittle it will pop off, sure it been on there awhile.
Old May 1, 2010 | 09:39 PM
LS12Fast4U's Avatar
Yeah im not a beginner man. ( the bolts are out heheheh ). I have pryed on it with a flat head for an hour now. Its glued so tight at the oil pan. You can tell its a virgin motor ( lol )
jjcamaro02's Avatar
Did you remove the two bolts from the oil pan? The cover should come off fairly easy.
