Scored a free 6.0, what to do
You can use a 6.125" rod with these pistons, and it ends up with "zero deck" at a 9.230" deck height. Have the deck cut another .010" so that the pistons are out of the hole .010" and use LS3 MLS headgaskets. Mill the heads to 62cc, and you'll have roughly 11.3:1 compression ratio.
However, my only concern is the pin used in these things. I've seen Probe use way too thin of a wall thickness in their pins, so you may want to call and see what it is first, and then maybe see if they have an upgrade. Also, they list using a 2.5" length pin. I've heard that other manufacturers use a shorter 2.25" pin for extra room away from the reluctor. Just a couple thoughts.
edit: this is going to be more on the race car side of things so it may not be as great of an idea if you wanting a great street car. My car already has alot of weight out of it and after i finish the th400 swap the next phase of mods is a manual steering rack, abs delete, and a 10pt cage. So were probly going two different routes here
Forced Induction
I will say if you are planning to do this, you are a very patient person. I've seen very few people finish a project that way (give up half way through collecting parts, or wife yells at them to get that "god damn car" off the jack stands and out of the garage), but I'm behind you 100% if you can pull it off
Forced Induction
