Patriot heads Vs TSP ?
I just wanted some feed back as to which ones have better fit and finish and workmanship. Also if anyone has used these what were your dyno numbers?
Thanks guys
Patriot 243 Heads CNC'd and TR cam 228/232 112+2 LSA.
So far, I have been pretty happy with the set-up. The car dynoed at 331 with bolt-ons.
After the H&C and the new wheels, it dynoed at 391.2 rwhp and 385.4 tq. The guys at the shop said it would easily be over 400 rwhp if I had smaller wheels.
Thanks guys
So as far as fit or finish goes, they should be the same. As far as numbers go, its hard to say. I know patriot has a 5 axis cnc they use, im not sure Prc uses(tsp uses prc for heads). I know alot of people have had great results with both companies, so i say pick one, and you wont be upset.
Chris
Chris
One of the biggest differences between us (and there are plenty, but this I'm very proud to say) is the online presence, support, and tech help that Texas Speed/PRC offers before and after the sale!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Not trying to be a nut-swinger by any means, but I'll give credit where credit is due.
Oh and the first dyno was a dyno jet, the second (after H&C) was a load bearing dyno...not sure how that factors in on the numbers as well.
Just thought that was pretty cool to post, maybe Newin is a chinese knockoff brand
