Cam swap help
Old May 7, 2010 | 09:14 PM
jrz28's Avatar
Default Cam swap help
I want to do a cam swap on my LS1. I bought a cam(218/234 111+2 lsa .60x intake 59x exhaust)and need to know what size springs, pushrods to buy.MY LS1 is stock other then headers n slp airlid. Please give some info.
Old May 7, 2010 | 09:32 PM
crainholio's Avatar
Check with the cam manufacturer.
Old May 8, 2010 | 09:36 AM
jlrz28's Avatar
10 Second Fun Car
I looked at the user name first and was like I didnt write this..but then noticed it was close. Just like said before check with the mfg.
Old May 8, 2010 | 12:33 PM
ssinister550's Avatar
get a good dual spring with pressure somewhere in the ~130 seat and ~400 open ballpark, and if you're going to be turning it past 6500 rpm get a good hardened pushrod that is same length as stock (7.400 i believe?) but i know as long as your not turning more than 6500 the stock pushrods will suffice as long as you don't mechanically over rev it ( if its a stick car ) but if you have the extra cash you might as well throw a good set of pushrods in it while your in there. as for springs patriot gold duals are a bargain they sell a kit with Ti. retainers, super 7 locks and viton seals for i think like 280 bucks, which is the route alot of people go... hope that helps
Old May 8, 2010 | 01:40 PM
garygnu's Avatar
pac 1218 or 1518 springs and some after market 7.4 push rods. WS6 store sells a spring compressor.how many miles on the car?mite need a new timing chain and it is a good time to replace the oil pump.go to LS1HOWTO.com for instructions.
Old May 8, 2010 | 02:40 PM
jrz28's Avatar
Thanks guys. Yes my plan is buying a new timing chain and a LS6 oil pump to. And i did want to go with harden push rods since my Camaro is a M6. Like I said thanks for the help.
