lq4 logical limit
) stock heads stock bottom and run it to 6800 redline quite frequently in a fairly light auto 96 impala ss. is this a safe redline? im worried im going to shoot me moneys out the sides of the block ive heard of arp rod bolts, is this cheap insurance or does it cost more than i want to spend? i plan on using ported ls6 oil pump just for safety. id like to sparingly use nitrous in the future. does this sound dangerous to anyone? please help im fresh on the nitty grittty with lsx and am starving for knowledge of every single aspect of this engine!!! Now you are talking about putting it in an impala ss. What is your idea of light? If you pulled the interior and ac you are at the stock f-body weight which is not too light. You will need a big stall and gears. Check into the Katech rod bolts. They can be installed with out resizing the big end of the rod unlike the ARP rod bolts.
I would stroke a 6.0l and put it in that car. More cubes will help get that big tank off the line.
im planning on mostly racing the car 3800 nitrous ready stall, 410's in the 10 bolt
im trying to get it down to around 36-3700 pounds roughly with my skinny 145 pound *** in it. i might try cleaning up the stock heads but not messing with anything major
does anyone have a rough estimate on rod bolt replacement? or can i do it myself with the Katech kit? im trying to do it on the cheaper side for what thats worth but if i could i wouldnt hesitate to put a 427 l92 in with a couple hairdryers!
3800 is not near enough to get some good 60ft from that tank. There are guys using 4000 in f-bodies. Plan on using something closer to that or bigger.
You can replace the rod bolts yourself and they are a lil more expensive than the ARP's. Bad idea on the l92's for forced induction. The heads have a thin deck which makes them prone to cracking and pushing water.
maybe i can get real lucky and find some cheap ported 241's on here or craigslist chicago gets hot sometimes, but its a long shot prolly gonna get stockers maybe for free from my buddy they are sitting in his garage. If you are choosing that motor, you need to choose another cam. That cam has no bottom end torque and a Honda with vtec will beat you off the line. You have a car that is more than likely too heavy for that cam. I am not saying you can't use that cam, but you will need a big stall and gears because the cam has no bottom end torque. The polluter is supposed to be big just like the MS4 but have bottom end grunt to go with it, so you might want to look into that.
