Spacers needed.
Old May 9, 2010 | 08:20 PM
cammedws6's Avatar
Default Spacers needed.
I have some vette rims on my 2000 trans am, and the rear tires are rubbing. Does anyone know where i could buy some 1" spacers? Thanks guys.
Old May 9, 2010 | 08:33 PM
peterlawl84's Avatar
tires rubbing on the inside or outside fenders? I assume inside, since you are looking for spacers...did you try the BFH mod first?
Old May 9, 2010 | 08:55 PM
cammedws6's Avatar
ya inside, on the fender walls. no i have not yet though.
Old May 9, 2010 | 09:30 PM
Might try the BFH mod first...if you add spacers, it might cause rubbing on the outside fenders (which you could roll if needed, but it still might not clear).
As far as spacer, I use 15mm upfront to clear my calipers, not sure where you could get 1in ones. But definitely make sure they are hub-centric.
